Swang
I have a 1984 crossfire that did not run well when I bought it several years ago but has been getting better as I go through it.
Current problem developed after I replaced the ECM. Car ran ok with the new ECM, but with the key in the off position I could hear a clicking sound coming from both IAC valves. This sound continued until I disconnected the wires leading to the valves.
Condition before repalcing the ECM:
1. Started ok and ran ok
2. fast idle when cold was ok 1100 RPM
3. Idled at 600 RPM when warm
4. Started hard after a long drive, stalled sometimes after hard start, ran ok afterward. Engine temp never much over 167 with low temp prom. Usually started ok after short runs but even on short runs had time to warm up to 167.
5. The following items are new: EGR, EGR solenoid, MAP sensor, Hypertech Prom, 160 temp switch, 160 therm.
6. Transmission rebuilt
7. New radiator
8. New mufflers & cat
9. New O2 sensor
Why are the IAC valves clicking with the ignition key in the off postion?
Could the IAC valves be stuck in an open position?
Can the IAC valves be cleaned?
7. New radiator
9. New O2 sensor
