S
slashnick
Today I got the oil changed at a Kwick Car. While the car was in the garage getting the work done, it started to rain. When I got in to leave, I pulled out of the parking lot and stopped at a stop light. The engine was idling at 1200rpm and would not slow down. I had to press the brake very hard to keep from rolling away (auto transmission). When the light turns green I let off the brake and the car accelerates to 50mph without even touching the gas pedal. When in neutral the rpms are up to ~2400rpm.
I returned to the Kwick Car and told them this just started when they did the work. They could find no reason for this to happen.
The gas pedal feels as if it may be sticking, possibility from the humidity. But I know there could be dozens of other explinations.
Also the car has an aftermarket X-ram intake manifold. Because of this there are loose hoses and tubes that go nowhere. I am getting the name of the guy who installed it so he can take a look.
Until then, has anyone else had this happen to them, or any other suggestions?
,in that order :gap
