AirJohn
Having issues with one of our 1985 Corvettes, it started running rough after it warmed up, running around 198 degrees or so, not getting too hot. 200,000 miles on this one. Sometimes it acted rough at highway speeds. Passed Calif SMOG test here 4 months ago. Engine ran great until it reached operating speed. First showed an error code of 54 that is the fuel pump circuit fault or mixture control solenoid fault (not used on this engine), or ECM failure, so the book said. Pressure gauge showed fuel rails around 32 so I replaced the pump and tank filter, showing 40 now. Replaced the main fuel line filter also. Replaced the fuel pump relay and harness connector, replaced the oil pressure switch at back of the intake manifold/block (Napa OP6624 and OP6638). Replaced the spark plugs with AC Delco CR43TS, still ran like crap when warmed up, most of the time.
Then I started getting code 44 (lean mixture), then 45 (rich mixture). Replaced the Idle Air Control (Master Pro 2-IAC1 21738), got the same codes. Replace the Oxygen sensor, the one I removed looked good and was a little sooty black (BOSCH 12014). Cleared the codes again, ran OK for a few short runs, then codes 44 and 54 are back again. I ran a fresh new wire from power back to the fuel pump directly, that did not help. (Unswitched power is always hot to the oil pressure switch, then goes to the fuse panel, then to the fuel pump, the fuel pump relay is only used when starting the engine, then becomes dormant and the oil pressure switch keeps the fuel pump operating). I removed the vacuum line from the EGR valve and blocked it off, thinking it was sticking open and not closing at idle speed, same results. I can not see the operation of the EGR valve, I am not wanting to remove the plenum to get at that valve if I do not need to do that. What am I missing here?
:duh
:duh
