1986 conv a/c fan out, fuses good
M
muzy67
Has anybody changed a fan, motor or possibly a relay in the circut. Where is the fan for the a/c? How about a relay for the fan. A/C compressor kicks on when selected but no fan air comes out even when vent air selected. Any help would be appreciated.
vigman
Motor head!!!!
Valencia, CA,USA
Were talking the A/C blower fan correct?
Is it manual or Auto climate control?
Vig!
M
muzy67
It is a manual control unit. I don't know where the blower moter is located and if there is a relay involved in the system. Thanks!
vigman
Motor head!!!!
Valencia, CA,USA
Locations
The blower motor is located on pass side under hood Just over the windsheild squirter resivoir.
The Blower resistors ( for speed control ) are located on the TOP of the blower shroud near firewall Connectors facing up 4 pin connector.
The blower relay is on top of the shroud as well Just above blower motor.
Check GROUND on motor FIRST.
The 25 amp fuse in box provides power to everything EXCEPT the HI blower.
Fusible link K does that
Check if you have power at the Blower relay
Pin A Red ( Power from Link K) Batt power
Pin C Blue ( Feed from blower resistors )
Pin D Orange ( Pull relay IN for Hi speed)
Pin F Black ( Ground )
Pin E Purple ( + line to motor )
Blower resistors
Pin A Yellow
( Feed from speed sw assy Low)
Pin C Tan
( Feed from speed sw assy Med )
Pin D Lt Blue
( Feed from speed sw assy Med-Hi)
Pin B Dark Blue
Feed to Blower realy ( Output to Pin C of Blower relay)
Start Here.... Let me know
Vig!
M
muzy67
Hey Vig, It was my blower moter. I didn't realize it was going to be that easy to change. Thanks again!:_rock
vigman
Motor head!!!!
Valencia, CA,USA
WOOF
Score another one for the VIG!
