S
strikercat
In the process of replaceing the valve seals.With help this past weekend started on the drivers side of motor.With the rockers and springs off on cyl. 1 we realized there was an o-ring on the intake and the exhaust valve.I had bought the valve seal kit from a local[Bennet Auto Parts]store,they sold me only the kit to do the intake valves,even though I made it clear what I was doing[I thought].We used the kit to finish the left side,I called the store and ordered the kit for the exhaust valves.This kit has the o-rings[like the intake kit] and "hats" that fit on the base of the exhaust valve.The factory didnt use the hats,just the o-rings on the exhaust valves,my parts man tells me the hats will make the seals last longer.One of my questions,should I go back and redo the exhaust valves and install the "hats' ,just leave the left side as is,do the right side and just use the o-rings or use the hats and the o-rings on the right side??? My second question,can the valve cover on the right side of the engine be removed without dropping the exhaust manifold on that side as the book says?Can the EGR pipe be removed from the manifold on the car? Any help/info much appreciated.
