topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
have to do a bit of work on this 1990 for a friend. it's cooling fan/fans run continuously from time car is started any ideas on why it would be doing this. Coolant leak always a puddle by the thermostat housing but doesn't appear to be coming from the housing itself. Fuel pressure, it is currently at about 56psi. He has a adjustable regulator so where should it be set for a bone stock L-98. and what is the correct procedure for setting it?
Motor has a continuous dead miss where you can feel the engine skip. however under a load you don't feel the miss this seems to be an idle only miss. Car also idles around 1100rpm all the time. Car has new injectors/tuneup/ o2 sensors etc etc. no service engine light is coming on .... where and how do you get the ecm to flash codes on this car?
Thanks for any help.
