dabailey2
New member
My 1991 has about 110k miles on it. I was driving it about a month ago and as I was about home (after driving about 50 miles) I was at a stop light noticed that it was idling a little rough as if it was going to cut off but not but then if i put it in park or neutral it ran smooth, so then I started to take off from the light and i noticed that it started to stall out like it didn't want to go the after about 30 seconds it would get up to speed and seemingly run fine. I got it home and parked it without really putting a lot of thought into it. about 3 or so days later I got in and it started right up, I drove it about 30 miles with no porblem so i thought it was okay. later that same afternoon got in it and drove about 20 miles then as i was slowing down at a light it cut off. It started right back up and then the rough idle and hesitation started again. This time it was much worse i tried to go about 5 more miles but it continued to cut off and the performance got worse. I after it cut off about 2-3 times and started right up on the first try, it cut off nad would not start..almost like it was flooded or not getting enough gas. let it sit for about 2 hours tried to started it, it started right up and i thought it would be okay to get home, drove fine for about 1 mile and then it started again. Changed fuel filter, fuel pump, strainer, spark plugs. Fuel injection pressure is within spec all the spark plugs fire. Still having the same issues
I have noticed that the battery charge light is on and the battery dies and this all started when this issue began. If i start the car now the right side of the engine gets hot to the touch but the left side does not, although it is not working but all the plugs fire on that side and they are not wet or anything. There was a wire next to the fuel injector that was a loose but when I hooked it back up the battery was dead so dont know if that did anything.
The speedometer went out about 2 months ago and I know that can effect performance but not sure how. Any ideas? I am stomped.
