Coupe de jour
I have the foolowing questions regarding the ZF-6 speed
Where can I get parts for the ZF-6 other than the basic seals that are available at the dealer?
Since I will have the trans out for a clutch replacement, what parts/other services are worth replacing at that time?
I need a new clutch and saw that Centerforce offers either their entry level clutch or the dual friction clutch. Right now the car is stock but I will be applying power adders shortly. Can the dual friction clutch be used for reliable street driving conditions or should I stick with the entry level replacement?
Can I disconnect the 1-4 shift solenoid at the transmission or do I need to install a pigtail inline to fool the computer? I am trying to avoid fault codes. If I need the pigtail where can I get one?
