1992 Bose Stero
jgus111
New member
Palmer Ma.
1992 LT1 Coupe
Hi My 1992 coupe has blown amps in the speakers. The radio was replaced before I got the car it is a Clarion radio. Is there a way to use the factory wiring and run the speakers with out the amps? Thanks Jim
Sure. There are wires from the Bose Unit to the speakers' amps. Realy all you need...if you know what you are doing. Having said that, the real problem is connectors i.e. connections. If you are clever you could cut & solder. What to do with the automatic antenna (if so equiped)? I would recommend going to a good radio shop and let them do it. Sure better ($) than new preamps for all the speakers.
