Ben Edwards
I have a 1992 coupe with an LT1 motor, all stock with about 62,000 miles on it. The problem I am having is after the engine gets warm the "Service Engine Soon" light will come on for about 2 minutes then turn off. I checked the codes and got a 63 and 64, which was lean right side heated 02 sensor, and lean right bank 02 sensor. There is also a slight lag in acceleration at low rpm's. I have replaced the TPS and the fuel filter and then cleared the codes. After clearing the codes she runs great for awhile then the problem starts again. I'm sure I will need to replace one of the right side O2 sensors, I am just trying to determine which one, or both, or if it is an entirely different issue all together. Any input on this would be greatly appreciated, thank you.
Ben
Ben
