Steve Barber
I have a 40th Anniversary convertible. For almost a year now I have been searching for a trained and reliable technician to replace the optispark. So about a month ago I found a local automotive repair shop that does work on Corvettes but is somewhat limited in their knowledge of the C4.
I purchased the optispark kit from Petris Enterprises and I am very satified with the purchase. The Petris optispark is an upgraded model that is vented like the later C4 optisparks.
The problem now is a Service Engine Soon light with a code 15 in the ECM. The digital coolant temp displays 142 degrees all the time while the analog gauge appears to display correctly. Also, the electric fans run full time even when the car is started cold. The code 15 is coolant low temp issue.
I think I have completed enough diagnosis that points to the ECM as an issue, not the coolant temp sensor or coolant temp sensor plug or wiring issue.
I thought I read a post a couple of days ago on this forum, before I joined, where someone else was having the same issue. But until I joined, I could not see the follow-up posts. And now i can't find the same post. Has anyone else had similar issues and what was the solution?
