I just bought a 1994 Corvette with a 6 speed that doesn't run. The following is the trail I have taken toward finding the problem.
1. Security key does work.
2. Clutch switch does work when I bury the pedal into the carpet.
3. The car starts, runs rough and then shuts off.
4. Checking the codes with the paper clip I got the following.
1. Reads C41, Loss of ECM serial data communication.
4. Reads ERR
9. Reads ERR
5. I did find a lot of corrosion on the big fuses under the ECM. Cleaning it off didn't change anything.
Any ideas? Jack
4. Reads ERR
9. Reads ERR
Any ideas? Jack
