gmjunkie
I believe your right Tom!! I don't know about changing the cam,but the timing cover and drive to the opti are different!!OK, I think you may be judging the car too harshly. Optis go bad, that doesn't mean that the car is a hunk of junk. I understand your frustration I went through it too. Check this thread.
http://www.corvetteactioncenter.com/forums/c4-technical-performance/106269-sort-stumble-idle.html
But getting rid of it is being a bit rash. Once it is fixed you should have yourself a nice car. I love my 94, and as frustrated as I got with it I didn't feel the need to ditch it.
Now on the "new style opti" without changing out the cam/cam cover I don't believe that you can use the new style. (I could be wrong.....but I doubt seriously that I am). That is one of the reasons that I went with an MSD unit vs GM. And besides the GM opti that went bad had only 6k on it.
BTW if you are still set on selling that POS after you get it fixed, I'll give you $1000.![]()
I know I won't change a Opti for $200. Labor!!But I know what I'd do before I changed the Opti,I'd be checking ALL the grounds,Especially thous miserable PITA 3 on the back of the engine!!
My bid's $2000. and he don't have to fix it,Flowery Branch GA ain't that far!!
