*89x2*
" 1994 CALLAWAY SUPERNATURAL CORVETTE LT1 435. Perfect car. Special features include: produces 485 hp at rear wheels (dyno tested), 383 cu. in. engine with Vortech Supercharger. 190 mph car. 0-60 mph in under 4 seconds. SuperNatural Dual Outlet stainless steel Cat-Back exhaust with 2.75 dual pipes. 3.10 gear ratio. LT1 Single Mass flywheel, CenterForce clutch. Series 1 Aerobody kit including nose, gill panels, sill extensions, lower door skins, tail cap, and lenses. Coil-over four-wheel independent adjustable suspension, progressive rate coil springs, threaded shock sleeves, and spring perches. Brembo brakes, front and rear Indy car Billet aluminum gold anodized 4-piston calipers with ventilated and cross-drilled nodular iron rotors, includes calipers, rotors, brackets, rotor mounting hats, extended wheel studs, and braided stainless brake lines. Fikse polished aluminum FM/5 5-spoke 17" wheels: 9.5" front and 11.0" rear. Goodyear Eagle GS-C tires: P275/40ZR17 and P315/35ZR17 rear. Call for additional options and photos. Offered at $45,000. Call Fred or E-mail @ fredv@krproducts.com. (831) 426-6061
Hope this helps someone in the market
