JimBobC4
Hello All ! Been a while since I have posted.
I finally found time to take the cover off my 1995 Convertable and noticed the power antenna no longer worked. The motor does make noise but it does not go up or down. I'm fairly certain a repair is needed.
My questions:
1. How hard is the antenna to replace ?
2. Do I remove it through the tag opening or the tailight ? or drop it out underneath ?
3. Has anyone just replaced the shaft portion ? I see it is about $ 100 less than the entire assembly.
4. What is the connector like on the unit ? Im sure I wont be able to see it when I remove the motor. I just don't want to break off any pins.
Thanks to everyone !
My questions:
