I have a 96 coupe with LT4/ 6 speed and it overheats when idling. I checked both relays and both fans run. I replaced the water pump and pulled the radiator, cleaning out loads of debris including blowing out the fins on the radiator and the condenser. Airflow is not an issue. Ran the car in my driveway for over a half hour with the AC on and it easily maintained the temp. The problem comes in when I turn the AC off. Is it possible that the low speed fan has no oomph anymore and is turning without moving much air? It climbs to 230 in a few minutes and drops if I get the car moving.
