eddie 96
I have a 1996 Corvette, with opti-spark. It has 7100 miles on it, and I have replaced the opti-spark 7 times in the last 8 months, or so. I always replace the oil seal, and the water pump does not leak. I have changed the ingnition module 3 times, and I had the car in an electrical shop to check for: tray AC voltage from the distributor, possible bad grounds, PCM, and they said that the car checked out fine, and to try a MSD distributor instead of an OEM Distributor. I installed the MSD, and it worked as a little solver for about one month. Now I am back to where I start, when a snap on scanner is hooked up to the car, it points to distributor failure. I have looked at the wire harness, and the car has never been butchered up. I got it with 42,000 miles on it, from the original owner.
If anyone can help, it would be greatly appreiciated, and I mean some one who really knows. I have been changing parts from the fuel pump to the ingnition switch, I have gotten suggestions from folks who were trying to help but really didn't know. I of course do apprieciate suggestions but if some knows anyone who has had this particular problem please help!
Thank You,
Eddie O
Thank You,
Eddie O
