Check your codes. I learnt a valuable lesson this weekend, trust the GM engineers.
I had hot air coming out the driver’s side and cold air coming out the passenger side of the HVAC ducts. Reviewing the forum I came to the conclusion that I was low on Freon. I started to add Freon and the pressure was already high enough.
I tried removing the fuse 27 and resetting the codes HVAC B0441 H which did not help. Well, I went to the book and HVAC B0441 H was for the left hand electric motor actuator. The actuator is $213 so my question was trust GM’s BIT (Built in test) or have the dealer troubleshoot and fix.
The lesson I learnt is GM knows what they are doing and replacing the actuator myself, fixed the problem. It was not a easy job removing the dash pad and getting to the actuator, but a satisfying job that I fixed the problem and saved 4 to 5 hours of labor costs.
