V
vettegirl
In a previous post I talked about my fans only coming on for a few seconds at a time. This weekend I replaced the all the relays and fuses in engine compartment fuse box that had anything to do with cooling fans. Now they run at "low speed" when a/c is on, when car gets close to 200 degrees they seem to go to "high speed" for a few seconds, then cut off. With a/c not on, they just do the "high speed" at 200 thing, but still only stay on a few seconds.
Is this normal? Are they supposed to be variable-speed fans (could not find info on this in manual)? If so, at what temperature do they come on and stay on without a/c on?
Thanks!!
Lauren
P.S. If you need relays, check PepBoys or AutoZone - they were $ 9.00 to $ 13.00 there, as opposed to $ 26.99 to $ 29.99 at dealership for same relays!
Thanks!!
Lauren
