Bought a 2000 convertible with 36K miles from the original owner/dealer. Have pix of the car when I bought it in March, 2004. The car sat "even". I could put "four fingers", pinky, ring, middle, and index between the top of the tire and the bottom of the fender on the front and rear.
After about a month, the front started to "sag". I was dragging the spoiler. Was down to "one finger" on the front. Adjusted the spring bolts "downward". Got the car back to "four fingers".
Started to sag again. I screwed the spring bolts in all the way in...with just the 10mm. hex bolt showing. Got back to "4 fingers", even after the car "settled". The car is down to "2 fingers" again.
Thought that the rubber ends of the spring bolts might be too worn. Went to Chevy and found that you cannot buy just the spring bolts...they are part of the entire spring assembly.
Can the fiberglass front spring "fail" so quickly? It looks OK to me. No splits, cracks, etc. This is driving me NUTS. The spoiler is dragging on my driveway, and on almost every bump in the road.
Suggestions? Thoughts? Has anyone replaced a front spring on a car with now only 38K miles on it? I'm baffled? Chuck
