R
rhancock
I want to change the stock 2.73 rear end in my '01 M30 to the G92 3.15 option. In cruising other forums I found info that is a bit confusing. Do you have to change out the entire differential (from the stock M30 2.73) to put the G92 3.15 option in place? I know you want a matched set when you replace the gears but I remember reading something about the other components in the differential being stronger in the G92 over the stock differential that came with my '01 M30 2.73. Somebody set me straight ! Please.
