M
madand043
2003 convertible noisy lifters
noisy motor. car started cold there is a valve train noise. if the car is revved to about 2000 rpm for 30 seconds the noise goes away. after the car idles for a while the same noise returns. car was taken to chev dealer once and was told this is "normal", however 6 other 03 cars started never made noise. sevice manager explained it as piston "made" to fit loose. i quoted service bulletin #02-06-01-038 found on this site and was told this does not apply to this car. there is only 6000 miles on this car and it has had 2 oil changes.
anyone else with same problem or with a solution or do i go back 2 more times and lemon law?
thank you
thank you
