Picked up the parts yesterday at dealer. 10331562 right and 10331563 left are the correct numbers for the moldings. Most other websites are not listing the correct part numbers for C5 Z06.
Does anyone know what caused the failure of the original parts? I want to make sure that this doesn't happen again.
What disassembly/assembly items do I need to be careful with?
Where do I start to remove the weather strip?
My research says that I should use a 3/16 dia rope of 3M caulk 08578 over the full length of the part and around each screw to assure a good seal.
Is this the correct weather strip adhesive number 3M 0811?
I plan to use 3M adhesive remover 08984 to clean up old adhesive.
What is the torque of the screws?
Any advise would be appreciated.
