2004 Corvette Convertible - Stock #8507A - Only 17,055 Miles!
MacMulkin Chevrolet
Nashua NH
Drivetrain
  • Engine: 5.7L LS1 V8 SFI (350 HP [261.0 kW] @ 5200 rpm, 375 lb.-ft. [506.2 N-m] @ 4400 rpm for manual transmission, 360 lb.-ft. [486.0 N-m] @ 4000 rpm for automatic transmission) (STD) (LS1)
  • Transmission: 4-SPEED ELECTRONIC AUTOMATIC WITH OVERDRIVE (M30)
Body & Interior
  • Exterior Color: TORCH RED (70U) (1 of 1,079 built!)
  • Interior Color: EBONY, LEATHER SEATING SURFACES (193)
Description
This beautiful 2004 Corvette Z51 Convertible with only 17,055 miles is in EXCELLENT condition and looks amazing! Load up the 12-disc CD changer in the trunk, lower the top and enjoy the warm summer air as you take advantage of this Corvette’s Z51 performance handling package! With new Goodyear Eagle F1 Runflat tires, you’ll have many miles of road ahead of you and never get stuck with a flat tire on the road!
Options / Highlights
STEERING COLUMN, POWER TELESCOPIC includes manual Tilt-Wheel
HEAD-UP DISPLAY includes digital readouts for vehicle speed, engine rpm, a performance up-shift guide for the 6-speed manual transmission, and readings from key gauges including water temperature, oil pressure and fuel levels
PREFERRED EQUIPMENT GROUP includes (UV6) Head-Up Display, (AAB) Memory Package, (DD0) Mirrors, inside rearview and driver outside rearview, electrochromic (light sensitive auto dimming), (N37) Steering column, power telescopic, (T82) Twilight Sentinel, headlamp control system (1SB)
WHEELS, HIGH-POLISHED, 5-SPOKE , 17" x 8.5" (43.2 CM x 21.6 CM), FRONT AND 18" x 9.5" (45.7 CM x 24.1 CM)
PERF. HANDLING PKG, PERF.-ORIENTED PKG - includes power steering cooler, stiffer springs and stabilizer bars
MEMORY PACKAGE 3 driver settings, remembers "presets" for 6-way power seat, outside mirrors, climate control, radio presets and telescoping steering column, if equipped.
SOUND SYSTEM, 12-DISC CD CHANGER, REMOTE (U1S)
Price: $27,995
For more information on this Corvette, call our Corvette Team today: 603-888-1121
Click here for more photos of this Corvette!
