vetteracer11
Hello. I have ordered a 2004 Z06. I currently autocross my 1994 Z07 Coupe. I have set my alignment for autocrossing as follows: Front Camber -1.0, Caster 7.3, & Toe at 0. Rear Camber is -1.0, and Toe is 1/16 IN.
Please tell me what the factory alignment settings are for the 2004 Z06 and what do you recommend for the best autocross alignment settings.
Also, I would like to install the GM factory 12 Disc CD changer in my new 2004 Z06. Is the existing wiring harness already in the Z06, or do I need to purchase the GM wire harness kit?? Is the factory radio already setup to work with the CD changer once I get the wiring harness installed? Is this a rather simple installation, or should I just forget about installing the GM factory 12 Disc CD changer in my 2004 Z06?
Thank you very much for all of your help.
Mike
Mike
