4 the ride
My 2015 coupe is making a popping and cracking sound overhead when the roof is installed. It seems to get worse as the ambient temp. raises.  I have removed the roof and it goes away.  I have used silicone grease to lube all obvious areas to no avail.  Anyone else experiencing this? Since my original posting of this problem I have run across information that C6's also had this problem and GM issued a fix bulletin (injecting a foam substance into the roof) and if this didn't work, they replaced the roof.  Can I be the only one out there with this problem??
Car has been to the dealer and is now fixed. Inserted or replaced shims in the latches which reduced tension.
