Question: 2019 ZR1 Front Splitter Endcaps
I am sure that it has to do with aerodynamics, which the vert does not exactly share with the coupe. If GM had found that the end caps helped the vert I am sure that they would be there.
GM was not concerned with stone chips, as you rightfully are. :)
n/a
Harlan Charles, the Corvette Program Manager, says the end caps are deleted on Convertibles with ZTK because of the aerodynamic differences between the two body styles.
n/a
