73383
Started the 383 for the first time last night. It sounds reeeeal good. As I was breaking in the cam, the header pipes from the two rear cylinders, (7 & 8), started to glow red. I had been running about 15 minutes, so I shut it down. The engine was not over heating, temp was running 180-190 F. Also it does not appear to be running lean.
Question 1) Is this normal. Do the rear cylinders run leaner.
2) Could valve adjustment have anything to do with
this.
Engine Specs.---- timing was set at 8 BTDC, MSD ignition, Sportsman II heads, 9.5 comp, Performer RPM intake, Holley 770 Street Avenger, 280 Comp Cam. Comp magnum rockers.
Dennis
this.
Dennis
