4+3 Rebuild or Install 6 speed?
larry bud
Rochester, MI
1986 "Speed Yellow" Coupe
Well, the 4+3 blew it's brains out last week in my '86. It got stuck in O.D. on my way home from work, so I was hoping it was just a stuck valve in the valve body. No such luck.
I dropped the oil pan, and there were some (a lot!) of pin bearings stuck to the magnet, along with some chards of metal. Obviously requiring a rebuild, I'd like to get opinions on what I should do.
First, which bearing do you think this is that blew out? Is it possible that it's NOT part of the overdrive unit?
My options:
1. Rebuild it myself. I've done a motor, repainted my car myself, redid the interior, but never done a tranny before, but how hard could it be, right?? Yeah, right. Read the Doug Nash rebuild thread with the 30+ steps required. But I've had this rebuilt before, and it lasted 6 years (about 60k miles). Is it worth the effort?
2. Get someone else to rebuild. Tough to find a good trans guy that knows about these.
3. Buy an already rebuilt OD, put it in myself. Not a bad option.
4. Go with the Richmond 6-speed. I haven't heard anything bad about these, and I ordered the back issue of Corvette Fever that Ken had recommended that has an article of this mod. This sounds like a sexy option, but can I justify the end cost??
Thanks for opinions!
Check out the other threads on this topic. Search the forums.
I'll bet you'll not be able to rebuild it yourself and most shops cannot. I sent mine to what I feel is the best shop, anywhere.
Call him. http://www.5speeds.com/
The '87 if a bit more robust and the older ones can be upgraded. This is the simplest way to go.
The O/D is nearly totally separate from the Super T-10, so the bearings were from it. There is an idler shaft that protrudes from the O/D into the main box, as photos will show. It's not hard to dis/re-assemble the two.
You don't state your mileage, but while I had it all apart, I'd have the 4-speed looked at carefully. Mine had cracks on nearly every tooth and wear-through on a number of teeth; and that's a stock (mostly) '84. The total rebuild of both will likely be cheaper than a Ritchie and require no cutting or other mods. The O/D is a tough unit, but needs regular fluid/filter changes.
:wmike:v
I was going to swap to Richmond but after I drove a 84 that had a Richmond I decided not to because it still shifted sloppy and had gear whine and I would just be mad if I spent teh cash and then it blew on me. I am really picky though, its a good trans but for me just not worth the money. The trans was $3450, shipping $100, yoke $80, speed sensors and other misc stuff $100. Its a big investment. I also thought of a t-56 swap or a ZX 6speed swap and neither were economical. well I now have my 4+3 ready to be taken out of my car and I am swapping a A4 into my vette after I rebuild it. This is no easy task either but a lot cheaper especially since I am going to rebuild the tranny myself with race clutches and a good shift kit and torque converter. I have looked into every aspect of tranny swap ideas and for a broke college student I chose to go with an auto, I like sticks better but this is a lot cheaper and I will be able to shift it like a manual with the shift kit I am installing. As far as the 4+3, my overdrive was rebuilt a few months ago and blew out because the stupid shop didn't know what they were doing. Even with the shorter shift linkage arms and such the 4+3 just didn't shift how I wanted it to.
