LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
I think I have the shifter levers all adjusted correctly, but it is hard to shift gears and reverse is grinding. With the shifter in netural, I started with the 3-4 lever and then adjusted the 1-2 lever. That was quite easy. But the reverse levers are giving me a pain. I used a bungee cord to hold the shifter towards the driver's side and adjusted the lever until the shifter tab would engage the reverse lever. But it seems that 1-2 lever is still moving along with reverse lever.
Anyone have a good method as to how to adjust these levers other than whats in the book?
Thanks,
LannyL81
Tucson, AZ
Thanks,
LannyL81
Tucson, AZ
