Secrets of the C5
U
UB2 SLOW
I already knew about some of these, but some I did not.
> C5 Secrets and Computer CODE
> -The little yellow "helper light" on the bottom of the
> rear-view mirror that illuminates the shifter area
> -That you can put your key in the driver's door and
> turn it twice towards the front to unlock the
> passenger door and a third time to pop the trunk.
> -That you can pop the trunk and also pop the gas cap
> cover by pulling on metal lines hidden in the back.
> -The little slotted cover on the dash behind the
> steering wheel is where the inside air temperature
> sensor is located.
> -All of the option codes are in the glove box.
> -Tire inflation recommended pressures are on the
> driver's door
> -The thing that looks like a little LED near the DIC
> buttons is a light sensor
> defroster vent is a UV sensor for determining A/C
> usage to compensate for the heating effect of the sun
> -The build sheet is in the front re-bar
> -If you leave your turn signal on, in about 1 minute
> it will start to ding (loud enough to hear over the
> stereo) to let you know you have old timers disease.
> -You can reset the oil life by pumping the gas pedal 3
> times (but not with the engine running)
> -Hold down the reset button while on one of the trip
> odometers and it changes that reading to the miles
> you've traveled since last starting the engine.
> -Hold down the Active Handling button for 5 sec. to
> engage "Competitive Driving" on cars equipped with
> active handling (2000 and previous years must be
> stopped.)
> -If you pull the seatbelts all the way out while
> you're buckled in, they ratchet back in to hold you
> tighter into the seat.
> -Simply remove fuse #2 under the hood and your DRLs
> will be out permanently. Only thing affected is that
> when you unlock at night using the key fob your front
> turn signal lights and back up lights will not will
> not flash. Your front turn signals will operate
> normally, however.
> -The side-view mirrors can twist both forward and
> backward, decreasing the chance of damage if struck.
> -There is a release opening with a flap to let air out
> of the car when the hatch is closed. It is located
> just above the driver side rear compartment, behind
> the carpet and on the side of the car. Not that it
> really works well.
> -Also you can ground your amp to a screw/bolt that
> holds the rear middle compartment to the frame.
> -If you have a 6-speed car you can pop the trunk when
> the car is running by lifting the e-brake.
> -There is a spot on the driver side just out of the
> middle compartment under the carpet for the lug nut
> key. You should have a compartment on the drivers &
> passengerÂ's side (in the trunk) and a center
> compartment.
> On the left (drivers) side of the center compartment,
> on the left side where the center cover fits, there is
> an 'indent' that holds the wheel lock key.
> -If you turn on the headlights, then go to parking
> light position, the lamps remain up but the headlights
> are not left on.
> -If you have the passive entry feature: If you lock
> your keys in the car, wait a few minutes and then
> shake the car. That will unlock the car.
> -HUD has a shift light for manuals.
> -You can easily shift the M6 trans up or down without
> the clutch if you match revs. (Not great for
> longevity, however.)
> -You can eject the cd from the in-dash player without
> turning on any power. Don't even need key in the
> ignition.
> -The cruise will disengage if you purposely make sharp
> side to side turns while cruising at say 60-80 mph.
> -When the engine is shut off, you can get the odometer
> reading by turning on the parking lights.
> -You can program setting #3 (both memory buttons at
> once) in the seat memory to run the seat back and
> steering wheel forward for getting in/out of the car
> with the engine running.
> - If you hate DRLs you can pull the e-brake ONE click
> and they go off
good information. The rear hatch opening with the key is totaly new to me.
Max
It's all new to me ;LOL.
Thanks.
:w
Guy
and if you press recall with the radio off, car on or off, it will display the time for a few seconds.
Bruce
Wow! Great info! Much appreciated.
Mary
How the heck did you find these tidbits out ? I like the one about turning off the DRL's with one click of the ebrake. Gotta try that one in the morning !!
I got an email from my father in law about them. I am not sure where he got the info, but I thought it would be great to post it so everyone could share.
I think the one click with the e-brake works on most (if not all) GM cars with the DRLs. It has worked on several Tahoes and Suburbans that I have owned. My sales guy told me about it.
The ebrake trick to turn the DRL's off didn't work. Does it matter if it's an Auto or Stick ?
I have a 2001 c5 and didn't realize I could display the inside temperature. By default mine displays outside temp. How do I change this?
-If you have the passive entry feature: If you lock your keys in the car, wait a few minutes and then shake the car. That will unlock the car.
The old key fobs had a motion sensor in them that would signal the car as you approached and unlock the doors. If you jiggled the car with the fob in it you could activate the fob mechanism. GM no longer makes these fobs, at least not for the vettes.
I've heard about this but never tried it:
If you start a C5 with the door open, accidently hit the key fob & lock the doors, get out and close the door, you will have a locked car running.
Which one do you have?
Most of these "secrets' are revealed in the owner's manual.
Zippy :) :)
Dayum!
I thought it was just transportation and a chic car (not in that order). Ya mean it's got brains too? I just push in the left foot, move the lever in the middle of the console, let the left foot out, push down hard with the right foot and go like hell. Why do we need all this other stuff? :D
> and they go off
This no worky on my car.:duh
> and they go off
Stick or Auto? I wonder if there is a difference. Have you tried the other stuff on the list and see if they work?;shrug
