Corvettefan
New member
I noticed that my front parking lights were working on the wrong filaments ( parking lights on the bright filament and the turn signals working on the dim filament which is for the parking lights . Could not find this strange problem and all of the wiring was in bad shape so I replaced all of the wiring harnesses from the dash forward including the new parking lights , turn signal switch , headlight switch , horn relay , etc . and I still have the same problem with everything new . All of the wiring for the back lights work as it should from the dash connector back . Everything is absolutely connected right and all grounds are secure . There is no explanation for this problem so the only thing I know to do is cut the wires at the new front light harness and switch the wires for the filaments but I hate to do that with new lights . If you have a C2 will you see if your turn signals are flashing on the bright filament and the parking lights on the dim filament ? Thanks in advance .
