vetteKID
Well, I went for a cruise at lunch a few days ago after about an hour of driving, stop and go, some 45 mph cruising. I pulled into a court to turn around and while placing it into first gear, it seemed "too easy". I then tried to place into second and it would not budge. It took some jerking and it finally got into second. So I limped home....in second. Pulled into the drive way and it went right into reverse. I let it cool down and I then messed with it for awhile and it seems that there is no neutral position. The clutch seems to be working fine, very smooth transition from clutch in to clutch out. I haven’t checked the linkage. I don’t hear any grinding, wining or clunking. There had been a strange vibration above 4000 rpms but I think that the timing was off, or the cam didn’t get broken in properly. any ideas?;help
