John Robinson
Gone but not forgotten
Every since I bought my car with 67K miles it has upshifted at wot at 4900 RPM. Four days ago I got it hung up on snow and rocked it back and forth with the asr off. During this I got an SES which I ignored. When I got out of the snow and back on clear pavement I noticed that something was differnet in how it was running. I was running about 20 MPH and punched the throttle about halfway and holy cow it took off. Next I repeated the 20 MPH speed and really got on it and it snapped up to 6300 RPM before upshifting. I rushed home and pulled the code and it was a DTC 72. Apparently in going back and forth between drive and reverse I broke something loose between the ecm reading the shift points and the switch on the transmission.
Now when I get on it at high speed it missfires and I get a DTC 55 which I have had before along with 63 and 64. I have taken electrical tape and put a couple of wraps around the vacuum nipples to tighten them up. I can tell you that the car idles much smoother now and am looking forward to another drive to see if this has any effect on the fuel starvation at high speed. Updates as I learn more.
