S
studiog
My shifter opening in the transmission tunnel was excessively cut so a Hurst shifter could be installed. I have repaired the tunnel and fiberglassed up the entire hole to make a good repair. I now need to recut the hole for the shifter. Can I use the shifter console plate as a template to cut out the proper hole or is the shifter hole smaller than the console plate opening? Thanks for any help.
