62 Horn Button help..
jims427400
Temperance Michigan
67 427 tripower,68 427 tripower,04 Z16, 62 340hp
I've also posted this on the NCRS site but I need help.. My 62s horn button doesn't seem to fit right. I push the button into the contact assembly that is mounted w/ 3 screws, it fits hard against the steering wheel and theres no room more toggeling for when you push the button it rocks a little that honks the horn.. It's flush against the wheel. No rocking.. Look at may pics and see if the parts look correct. I have already looked at the assembly manual and looks ok.
Thanks,
Jim
You have some parts missing - I don't see the brush contact and tubular plastic insulator it fits in in the large hole in the steering wheel hub. The "leg" on the contact assembly contacts the end of the brush and completes the ground circuit for the horn when you push on the horn button.
Thanks again John. Do you by chance know the part #s for those? I've checked Paragon and Zips but cant find the pcs. your referring to.
Jim
