quick question , where does the hot wire hook up to . I have the wire off the motor , there is no fuse link , and its length only seems to reach the coil . I need to know where to hook it up Matt
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
Yes it goes to the ballast resistor on the same side as the brown wire from the ignition switch. The other side has a dk green wire that goes to the coil and S terminal on the starter solonoid.
