F
FireFly
First time poster to the site - glad I found it.
I have a 1965 with a 4 speed manual transmission. Unfortunately I do not get to drive it as much as I'd like - the cold winters here in NH don't help matters much.
When I tucked the car away for storage last fall everything worked fine. When I started it up last weekend I found a problem with my clutch. It does not work.
The pedal is hard to push in. With the car in gear I can attempt to start it but it will lunge forward, even with the clutch pressed in. I can start it in neutral but if I try to put it in gear with the clutch pressed in, it grinds - did this only one time.
Any thoughts on how I can fix this myself? I'm not the most mechanically inclined person but I have done a lot fo work on the car by myself and with others.
Thanks for the help!
