65 is painted
61 Silver
Wyoming N.Y.
1961 270HP and 1963 340HP
I just brought the 1965 home from the paint shop. I plan on de-nibbing (if that is a word) wet sanding and buffing this weekend. The paint is PPG basecoat-clear coat. This is my first attempt at rubbing out a B/C paint. Are there any suggestions for the grit of sand paper for wet sanding, de-nibbing and type of buffing polish and pad (pads)?
to use?
Thanks for any help!
Ray
Boy I was a way for a little while and some how I missed everything.
I cant give any advice to you.But I can tell you that car sure is shiney. Good luck with it and dont rush. I sure hope paint daddy or john McGraw stop in on this post
to use?
Ray
It's getting a little late
To explain the complete, and proper sequence of all the necessary steps to complete the job would fill the CAC board this evening, so I will address only the basic procedures.
Normally it is best to sand and buff within the first 24 hours, after the final clear coat has dried. The longer you wait after that, the more difficult it becomes because of the surface, that gets progressively harder, there by making the sand/polish operation much more difficult to accomplish.
As far as recommendations, I would go with the 2000 grit, and stay with a high quality paper such as 3M. This is not a place for the cheapie supplies. You will need an electric buffer, and it is imperative that it be one with a variable speed.
The best pads I ever used were also supplied by 3M and they were not the flat type, but rather those ( check pic ) filled with a pattern of little knobs.
As far as the compound itself, it would be better to inquire at your local auto-parts supply, because most have their own brands, and often they have employees who can recommend the exact products you should be using.
Before starting the sanding procedure, be sure your surface is absolutely spotless, because any dirt that's on the surface will be sanded into your new finish and I promise you , you will not be a happy camper. The regular size sheets of paper should be cut in half and folder in three, before letting a few of them soak in a plastic pail of lukewarm water for at least an hour before use. You also want to be sure to put two to three drops ( no more ) of dish washing detergent in the pail you will be using. The use of the soap will make a world of difference in your sanding.
You will need a small rubber scraper about 2" by 3" and keep it close because as you sand a small section of the surface ( 12" by 12" max ) at a time, you use the scrapper to check the progress. The surface will be ready to buff when the clear has completely lost it's sheen, and become ( after scrapping ) completely dull. I must ad that the sanding procedure must be completed on the whole car before attempting to start buffing.
All during this sanding process it is imparative that you keep the work surface, and your paper, soaking wet. Normally most people in the trade sand with one hand, and use the other hand to keep the sanding surface dripping wet, with either a large rag, a sponge, or directly with running water using a rubber hose held close to the surface.
In closing, ( and you will wonder why I didn't mention it before ) I would strongly recommend that you do not attempt to do this by yourself, it being your first try. I beautifully painted Corvette such as yours, is not really the right place to go through the learning process. I admire your courage, but if you have a mishap, and slightly cut through the surface, it's back to the paint shop once again, and I'm sure this is not something that will please you.
I can still remember the first time I did a complete job of sanding and polishing a Corvette. After having someone over for a few hours for some " hands on " It took me a complete week of evenings in the garage to sand and buff the complete car. So this is definately not a weekend thing.
Get help, have a professional come over and get you started so that you can see for yourself exactly what is involved. This response may seem lengthly but believe me, I have not even scratched the surface ( no pun intended ) as yet.
P.S. Regarding the paper, some sell the paper in smaller sizes then is normally seen , so you will need to adjust the size accordingly
Good luck with the work and the decisions
Bob
Paint
stepinwolf
Thanks for the reply! This will be the third time that I have rubbed out and buffed a Corvette. The last one never left my barn. I did everything including the painting, but it was lacquer. The information that I was looking for is exactly what you provided and confirmed the information that was given to me by the painter. I was supposed to re-paint the 65 (another story and previous posting) with BC/CC and it was to be a learning process, but a friend/body man needed the booth and painted it for me. The clear has been on since Thursday and the rubbing process will start today.
Thank you for your help!
Ray
Your welcome Ray
You initial post ( including some of the terms you used ) lead me to believe that this was the first time you were attempting the process. However in hindsight I have reviewed the post and can now see how why I had mistakenly thought that it was your first try.
Good luck, don't forget the detergent, and be sure to let the paper get soaked completely before using.
BTW, we will all be expecting to see some close-ups of all this, once you get the job done :D
Bob
Thanks! Bob
Looking for all the help I can get.
Ray
