John Mcgraw said:
Bob,
I am still using the old Ecklers bonding adhesive. I just have never found an adhesive that I like working with as much. A lot of the adhesives are just too thin and tend to drip off the bonding strips, but the Ecklers stuff is very heavy bodied. Several people have told me to try the Fusor stuff in the dispenser tube, but I just have not gotten around to it. I will try it on some smaller parts where the learning curve will not have such serious consequences. What is the deal with the Axson bonding adhesives?
Regards
John,
From what I was lead to believe, " AXSON " is one, if not "the" premier adhesive manufacturer, and not only do some of the fiberglass manufacturers actually use it to assemble their clips, they will also sell it to you outright. I have purchased it from a few different suppliers in the past, and I have a feeling that some of the others repackage the product with their own label.
My problem in Canada is that most of the shipping firms consider bonding adhesive as being a " HazMat " and will not transport any regardless if it is shipped air or ground. For that reason I normally try and purchase a sufficient quantity when I am at the Carlisle show, and try to make due until the next trip south.
With a few projects on hand, this building season saw me with an insufficient quantity, and was obliged to try and source some locally. As luck would have it , after visiting their site and a few back and forth e-mails, I was able to find some less then fifty miles from my place. This turned out to be a Godsend, because I was made aware that they " AXSON " actually supplied many different bonding adhesives, and one in particular, was much better suited to our bonding of panels, then what was previously sold to me.
The regular bonding adhesive that I purchased in the past was labeled APF-7 and was the correct black color. However the technical info they supplied indicated that they had another version the APF-4, that was much better suited for " bonding " then the APF-7 that I was used to using. I then contacted one of my suppliers, " Sermersheim's " and was told that they carried the black version APF-7, because it was of the proper black color, for a correct restoration.
The technical information concerning the various applications indicates that the APF-4 is better suited for bonding panels then the APF-7, and that it has a lower shrink rate. They recommend that the black be used as a repair adhesive for fiberglass molds. The only inconvenience of using the APF-4 is the color which is light gray, which would be an incorrect color for a correct restoration.
For information regarding the above mentioned products, you might want to take a look at the following link,
http://www.axson-na.com/Axson-NA_fillers.html and contact them for specific applications.
regards
Bob
a.k.a. Stepinwolf
