'65 rear deck emblem location
fredd65
ohio
1965 nassau blue convertible
redoing a '65..bought it stripped down to bare fiberglass...no holes for an emblem on the rear deck..does anyone have the dimensions as to where it goes?...from pictures, it seems to end end directly above an imaginary line from the center of the inboard tailight...so..if looking at the car from directly above, i know the side to side location...what i need to know is the distance from the crown right above the center of the inboard tailight to the bottom right corner of the emblem...the block letter stingray...if anyone knows, or has a diagram...it would be greatly appreciated....you can email me at rfrederick@woh.rr.com..thanks a ton...fred
Ok here's what I have
64 with 3 taillights
#3 is the one closest to the license plate and I believe the ADD ON.
From the rear deck edge ( centerline of bulb)
3.5 inches to base of StingRay rectangle.
From the #2 light ( CL ) which is the inner one on yours...
3.25 inches to base of StingRay rectangle.
And from the raised countor in the rear deck ( pass side) to the side of StingRay rectangle.7.5 inches
Hope this helps
Vig!
Look underneath
The holes MIGHT just be filled in, and goo hanging out the bottom.
Vig!
