V
Valkguy
Hope someone can point me in the right direction. Sometimes when I open the throttle quickly on my 69 350/350, it just shuts down. I'm not experiencing typical Q-Jet hesitation, it's like someone turned off the key. This happens intermittently. I tuned it up last weekend.
Dwell - 30
New Plugs - .035
Timing - 4 deg BTDC with vacuum adv hose pulled and plugged. I've read contradictary specs on the timing. The owner's manual calls for 4 deg BTDC the Haynes manual calls for 8 deg? Any thoughts on that one???
Vacuum adv was leaking so it was replaced.
Idle holds true at 750 RPM
2 year old rebuilt carb
195 deg thermostat, gauge reads straight up 210 deg, per the owners manual. Never higher, or lower after warmed up.
Plugs looked great when pulled for replacement
The car runs great, really smooth. Most of the time.
Can I be getting a vapor lock?? This has been happening for a year or so. Both fuel filters were replaced when it started.
Suggestions???
Dwell - 30
New Plugs - .035
Suggestions???
