69 l46 carb
tls630
Cape coral Fl.
69 roadster 88roadster
I need a good qudra-jet carb for my 350/350. The part #is7099207 I would like one that is in rebuidable condition.Also black seat belt for the right side, the long part that goes behind the seat and also the bracket that fastens it to the floor.Possibly an intake #3927184 IN GOOD CONDITION.
THANKS Tom
Hi . I've got the intake , maybe the correct carb and seat belt . I'll double check dates , #'s , etc. and send you an e mail . Geo
Geopar
How much do you want for the intake? And how much is the shipping.Please advise on this and the other parts.
Thanks Tom
The intake is in great shape ----$75.00 plus I'm guessing $20.00-$25.00 shipping ? Which belt do you need , outer(by the door) or inner (by the em.brake console) ? Geo
belt
Geo
I need the outer belt in black, I also need the accelerator support that bolts to the piece that fastens to the piece on the firewall. Its black plastic and has 2 bolts that go into the piece on the firewall.
Tom
How about the CArb?
Hi . I have several black and some blue(dye ?) outer belts dated from late '68 to late '69 . Can you get me an exact measurement(length) of the one you need ? Are you lookind for a belt that is std. , or one for shoulder harness set up ? I have all the acc. pedal parts for both a '68 and a '70 -- do you know which is correct for your '69 ? ( guess I can look it up in the AIM books) . The spreadbore Qject I have has these numbers on it----17054919 and under that -- 1308 . Will this work for you ? Let me know , George
Geo
The seat belts I have are std. lap belts. The piece I need is about 33-34 inches long and it has the lenght adjustment on it, I need black and a very late date in 68 would be good my car was built in Feb. 69 so it is an early.I think the black plastic piece I need for the accelerator pedal support would be the same as your 70, I saw a 71 chevelle and it was the same. The carb # I need is 7029207,yours is quite a bit newer than what I need.
Thanks Tom
Hi Tom . Ihave a very nice 44 B 68 dated belt with a very nice buckle ( I assume you need the buckle too ?) Send me your e mail address and I'll send you some photos of the belt and the acc. piece . Thanks , George geopar@gvtc.com
