71 Ignition Wiring Question
  • Thread starter Thread starter 73Roadster
7
73Roadster
I have a 71 LT-1 without the TI ignition and I'm not sure how to connect the wiring to the coil.
I believe that the Yellow resistor wire that is combined with the black/purple wire connects to the poisitve side.
Where does the negative side connect in the harness?
and I believe the points simply connect to the positive and negative side.
Thanks,
Ron
Points connect to coil negative. Both the 12 VDC wire from starter and the reduced-voltage resistor wire connect to coil positive.
JACK:gap
