69MyWay
I know we planned on a regional tech session, but my back is against the wall time wise. I had to push forward this weekend.
Below are pics of the front fender flare install. The trick to this is the flares are made for 68-69 cars. I had to work the lower portion of the flare to match the factory mud splash flare and make it look factory.
The process is as follows.
1. Hand mount flare on car, position to desired location.
2. Tape in place, then zip screw in place.
3. trace around flare with a nice sharpie
4. pull flare off, measure 3/4" below the trace line for the cut line
5. Cut the fender off at the cut line (ouch this hurts, because there is no turning back now).
6. Grind the back side of flare and fender
7. Mix a mild fiberglass reinforced filler (long strand).
8. Smear filler on the 3/4" lip
9. Push flare on car, and rivet through the mounting points
10. Push and smear the filler in tight from top and bottome.
11. Grind excess, and mix more filler for rivet dimples.
12. Grind again, and put one layer of fiberglass matt over the joint.
13. Grind high spots
14. Now start will regular light weight body filler
15. Long block at all different angles
16. Skim filler
17. Primer
18. block primer
19. More primer
20. Guide coat and spot fill
21. YOu are ready to move on to the next project.
This pic is how large of a piece you cut out of the stock fender to prepare for the flare.
16. Skim filler
17. Primer
18. block primer
19. More primer
