G
		Gary42
I had a hair-raising experience this week. When I started my '72, I noticed an odd sound coming from under the hood. I quickly realized that it was the starter and that it had failed to disengage even though I had turned the key back on the ignition. I tried moving the key back and forth, but I couldn't release the strater OR kill the engine! I didn't know what to do. Fortunaterly, the engine stalled within about 15 or 20 seconds of this. The starter is probably cooked now. Worst-case scenario is broken teeth on the flywheel. Best case: just a bad starter. Here's the odd thing: the ignition key now turns power on and off in a completely normal manner. It's not stuck closed. Why couldn't I stop the engine when the starter was stuck on? Anyone ever have this happen? Also, how hard is it to change a starter on a 72? Looks easy enough from my cursory inspection.
 I agree that you have a bad solenoid.  My local starter/alternator shop rebuilt my buddies 73 starter a month ago for $65 and only took about an hour.  We actually stood there and watched him put in all of the components.  Please ensure you use good jack stands when you have the car up.
