'73 Shifting Question
C3Vette Lady
Active member
San Jose, California
1981 Red Coupe, 1973 Big BlockStingray
Does anyone with a '73 manual big block know for sure if one needs to depress the lever on the shifter to come OUT of reverse to neutral????? I have tried both ways and can't figure out which is the correct one...:eek
Nope, you only have to lift the t handle to get into reverse.
Mike
The reverse lock out, the "T" handle on the shifter, should be only to keep you from accidently putting the car in reverse, should not effect taking it out of reverse.
tom...
Shifting from reverse responses
Thanks for your help and I love the "73 Spot" (sounds like G spot) site! Gotta get pics taken of my custom plates on my '73 (VETRESS) and send in. :J
When the car is on level ground,
and the engine is off.... does the car shift SMOOTHLY from any gear into reverse ( with the clutch in )?
And does it "feel" the same with the engine running?
If not...you might have to adjust the linkage for the clutch to get more
dis-engagement ( more pedal )
Have the linkage lubed for the gear shift while your doing maintance.
It helped on my 73 ( small block )
Vig!
Reverse Shifting
Mine clicks too, but I find that I have to wiggle it around a bit first to make that click happen. If I am backing out of the driveway onto the street, which is busy, I have to make sure I allow enough time to play with it to get it to leave R and go into 1st. It is not a quick and smooth operation. Seems like it should be. I will try that process Vigman suggested. I just don't want to be rear ended trying to switch gears! Not quite ready to wrap my ass in fiberglass!!! Thanks for your ideas--
