73shark
First disconnect and plug the vacuum advance hose. Set your idle to factory specs. Hook up your timing lite and loosen the distributor hold down clamp. Now turn the dist. until the timing is correct. Don't be surprised if the idle speed changes. Reset the idle speed and recheck the timing. If the timing is changing at speeds below 1,000 rpm, then the mechanical advance is starting to come in. You can measure and plot your mechanical advance vs rpm if you have a dial back timing lite or a degreed harmonic balancer.
As someone suggested earlier, a kit that w/ get you all in by 2,500 to 2,800 rpm w/ work w/ the L-82. When done hook up your vacuum advance and reset idle if necessary. If you are using the ported vacuum, you probably won't see much change but if you are using manifold vacuum, then the rpm should jump up 100 rpm or more.
FWIW, I was using 12 degrees initial timing w/ mech all in @ 2,500 on 87 octane w/ the stock L-82. Now w/ 10:1 CR and a slightly more aggressive roller cam, I'm not sure where I'll wind up. May have to go w/ higher octane. Just have to wait and see.
