A
Ala75Vette
After letting this problem ride for quite some time -- non-functioning power windows -- I finally decided it was time to put the problem to bed, and fix the windows. Both windows don't work. I thought I isolated the problem to the power window relay -- if I 'hard wire' the connections for the relay, the windows work. So, I ordered a new relay from MidAmerica. Genuine GM part, the replacement being pn 07729602. Well, with new relay installed, windows still don't work. If I pull the relay and 'hard wire' the connections, windows work. This is one of those times where I wish I'd taken more EE classes in college, or at least were a bit more electrically inclined. I don't want to 'bubba' the connections & put it all together again, because soon as I do I'll only be creating more problems in the near future, and it's a major PITA tearing down the dash and console to get to that stupid relay. Mostly I want to do it 'right' but I'm having trouble figuring out exactly what that is. The breaker in the fuse block is OK (already checked it); the pink connector in the fuse block is OK (gotta have it for the whole thing to work, which I can do by hard wiring the relay connections). My two thoughts are: grounding problem (or short circuit) somewhere? or, the replacement relay isn't a 'true' replacement.... At this point I'm frustrated, a bit ill over the matter, and happy for any advice you guys may have.
Thanks in advance....
Frank
Frank
