B
BobbyBJr
Hello,
We have a 75 Vette that has given us all sorts of carb problems since we have had it. At least that is what we thought. It is normally impossible to start and won't idle until the temp gets up to about 180 or so. I have been adjusting on the carb for over a year to get it to run so we can drive it every now and then. Recently, the car wouldn't start at all and I thought it wasn't firing, so I replaced all the plugs, the point and condenser set and the coil and after playing with the adjustments I finally got it to fire and to start. Oh yeah, while buying the parts I found out the engine isn't original. I think it is a 73, but I haven't checked the numbers to know for sure. Anyway, since doing all that and getting it to fire again, the car starts and runs 100% better. I just started it today after sitting for about a month and it fired right up and idled fine in just a few seconds. I drive it around the community and it ran fine. Okay, I guess the question that has been in the back of my mind is, "How did changing the plugs, point and condenser set and the coil solve the starting and idling problem?" Obviously, I am not a mechanic and don't pretend to be one. The wife and I saw the vette about two years ago sitting in a yard and stopped and bought it to play with. Any help or advice will be appreciated.
thanks,
Bobby
thanks,
Bobby
